Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Is it expected behavior for Volume efficinecy settings on SnapMirrorĀ source changed to be false after AFF snapmirror resync?
166
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
dp
Last Updated:
Applies to
ONTAP 9.3 + AFF
Answer
Yes. it is caused by ONTAP 9.3's design limitation.
Additional Information
ONTAP has a design change after ONTAP9.3 as below.
volume efficiency show after
resync src ->dst -> break
-> resync dst ->src
AFF + ONTAP 9.3
AFF + ONTAP 9.4 or later
original source
                           Efficiency Policy Name: auto
                                      Compression: false
                               Inline Compression: false
                                    Inline Dedupe: false
                                  Data Compaction: true
                Cross Volume Inline Deduplication: false
            Cross Volume Background Deduplication: false
                         Extended Compressed Data: true
                                      Compression: true
                               Inline Compression: true
                                    Inline Dedupe: true
                Cross Volume Inline Deduplication: true
            Cross Volume Background Deduplication: true
original destination
                           Efficiency Policy Name: -
                                      Compression: false
                                      Compression: false
Scan to view the article on your device
