NetApp Knowledge Base
How to set up ONTAP S3 as object store for Fabric Pool on remote cluster using HTTPs
640
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP S3
  • Fabric Pool from remote cluster
  • HTTPs
  • SSL certificate verification enabled
Procedure to set up ONTAP S3 as object store for Fabric Pool on remote cluster using HTTPs with SSL certificate verification enabled
Difference between Fabric Pool on local cluster and remote cluster
  Fabric Pool on LOCAL cluster as ONTAP S3 Fabric Pool on REMOTE cluster than ONTAP S3
vServer to create S3 server configuration Cluster Data SVM with -services data-s3-server
LIF used from S3 server side Cluster LIF listening on specified port LIF with -service-policy that has -services data-s3-server
vServer type that hosts ONTAP S3 bucket Data SVM Data SVM with -services data-s3-server
vServer type that hosts ONTAP S3 user Data SVM Data SVM with -services data-s3-server
Is Fabric Pool license required? No Yes
IPspace to create Fabric Pool configuration Cluster Default
vServer type to create Fabric configuration Cluster Data SVM
LIF used from Fabric pool side Cluster Inter-Cluster
IPspace to create S3 server configuration Cluster Data SVM with -services data-s3-server
vServer used during Fabric Pool attach to aggregate  Data SVM Data SVM
