NetApp Knowledge Base
How to rename a Vserver in clustered Data ONTAP
2,286
Visibility:
Votes:
1
Category:
data-ontap-8
Specialty:
core
Last Updated:
Applies to
Clustered Data ONTAP 8
  • Vservers can be renamed in clustered Data ONTAP 8 without any disruption to client machines.
  • This is because the change will not be visible to clients as they connect to the Vserver using the protocol addresses and normal hostname resolution.
  • Note: This Knowledge Base article is only applicable to clustered Data ONTAP 8, and does not apply to ONTAP 9. ONTAP 9 does not have the same SVM peer relationship and SVM rename interaction.
  • For more information, see KB What are the implications of renaming an SVM in clustered Data ONTAP?
New to NetApp?
