NetApp Knowledge Base
How to move a port from one broadcast-domain to another broadcast-domain while LIFs are using the port within ONTAP 9
4,049
Visibility:
Votes:
9
Category:
ontap-9
Specialty:
network
Last Updated:
Applies to
ONTAP 9
  • Within ONTAP 9 networking ports are organized within broadcast-domains
  • After a port is added to a broadcast domain you might wish to move that port to a different broadcast domain
  • If the port is the home port for a LIF or currently hosting a LIF, attempting to remove the port from the broadcast domain will result in this error:
cluster1::> network port broadcast-domain remove-ports -broadcast-domain BD2 -ports cluster1-01:e0c
Error: command failed: Port "cluster1-01:e0c" cannot be used because it is currently the home port or current port of a LIF. To view LIFs with a specified home port, use the "network interface show -home-node <nodename> -home-port {<netport>|<ifgrp>}"command. To view LIFs with a specified current port, use the "network interface show -curr-node <nodename> -curr-port {<netport>|<ifgrp>}" command.
New to NetApp?
Scan to view the article on your device
