How to identify full volume name from qos statistics output
Applies to
ONTAP 8.3
ONTAP 9 and later
This KB will help Performance TSE’s or Customers to see the full volume name while troubleshooting/monitoring Performance issues.
- qos statistics volume latency/performance/workload show commands is used to see the performance on the volume/workload.
- However, because of character limitations full volume/workload name does not show up.
In those scenarios run -showallfields
command to view the full volume name.
- One way is to identify the volume ID where high latency/throughput has been observed and then from ASUP in volume.xml section can search with volume/workload ID and then can identify the full volume name based on the volume ID.
- But this would take time and not in every issues ASUP is available to help as Bank or Other secured Customers may disabled ASUP due to their business requirement.
