NetApp Knowledge Base
How to identify controller chassis slot position for AFF and FAS models within ONTAP
204
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF Models
  • FAS Models
NetApp AFF and FAS models are configured within a chassis that can hold up to two controllers.  Depending on the model the configuration will be either a top and bottom controller configuration or left and right controller configuration.  Note:  For left and right configurations it is designated as you are looking at the chassis from the back of the system where the controllers are inserted.
New to NetApp?
Scan to view the article on your device
