Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
How to enable remote access to a node root volume in a cluster
3,054
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
  • This article describes the procedure that should be followed to enable remote access to a node’s root volume in a cluster.
  • ONTAP 9 does not export the node’s root volume using the SMB or NFS protocols.
  • HTTPS access to a node's root volume is available if the node is online normally or if it has been taken over by its HA partner.
  • The HTTPS access to a node's root volume is controlled by using the same authenticating username and password that is used for SSH or System Manager access, to administer the cluster.
New to NetApp?
Scan to view the article on your device
