NetApp Knowledge Base
How to enable Netapp Volume Encryption (NVE) on existing Snapmirror volumes
1,559
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Snapmirror (SM)
  • NetApp Volume Encryption (NVE)
  • ONTAP 9.1+
The procedure in the article outline the steps needed to encrypt a Snapmirror destination volume.
NOTE: The encryption configuration is unique to the cluster in which it was configured. In some instances, encryption is not enabled on the Snapmirror destination cluster when a Snapmirror relationship is initialized. ONTAP displays a warning when this configuration is detected:
Warning: You are about to establish a SnapMirror relationship between an encrypted source volume "SVMA:vol1" and a non-encrypted destination volume "SVMB:vol1_dp";
         you might want to use an encrypted destination volume for consistent security on both the source and destination.
Do you want to continue? {y|n}: y
New to NetApp?
