NetApp Knowledge Base
How to disable RSDT
397
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
legacy
Last Updated:
Applies to
  • Data ONTAP 8.2 and later
  • Remote Support Diagnostics Tool (RSDT)
As of September 1, 2016, the Remote Support Enterprise (RSE) service solution is (EOL) End of Life and no longer supported.
  • Refer to Product Communique CPC-1603- 04 for further details.
  • NetApp strongly recommends transitioning to AutoSupport OnDemand (AOD) for remote support on all storage systems using Data ONTAP 8.2 and later.
  • AOD is a Data ONTAP 8.2+ software feature that enables remote support by NetApp technical support through on-demand collection of information through AutoSupport. For more information: TR-4444: Data ONTAP AutoSupport and OnDemand Configuration
New to NetApp?
