NetApp Knowledgebase
How to decrease the number of inodes for a volume
995
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
Clustered Data ONTAP 8.x
ONTAP 9
Answer
The inode count of a volume in Data ONTAP cannot be decreased.
  • Each file takes up one inode and the default number of inodes allows 1 for every 32KB.
  • Increasing the number of inodes might be required in specific scenarios. For more information, see the following articles:
  • The maxfiles command can be used to increase the number of inodes that cannot be reversed in Data ONTAP versions prior to 8.0.
  • In Data ONTAP 8.0, this number can be decreased to the number of files stored on the volume or greater.
  • Certain file virtualization software/appliances might not work in the desired way, if the number of inodes in a volume is very large.
  • If decreasing the number of inodes does not work, then the suggested workarounds are as below:
    • Run the ndmpcopy command to copy the data to a secondary volume, which will reduce the number of inodes on the new volume.
    • Use Qtree Snap Mirror.
    • A complete backup and restore.
Additional Information
N/A
