Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
How to create aligned partitions in Linux for use with NetApp LUNs, VMDKs, VHDs and other virtual disk containers
879
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
san
Last Updated:
Applies to
  • Data ONTAP 8 7-Mode
  • Data ONTAP 7 and earlier
As a best practice, NetApp LUNs should always be partitioned with a single primary partition. The partition serves two purposes. It functions as a label for the LUN or virtual disk which helps the operating system identify the contents of the LUN or virtual disk. The partition is also used to align the host's file system with the LUN or virtual disk. Aligning the host file system is necessary to achieve optimal performance of read and write I/Os.
New to NetApp?
Scan to view the article on your device
