Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
How to configure and troubleshoot NTP in ONTAP 9 using CLI
11,344
Visibility:
Votes:
4
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
Network Time Protocol (NTP) in ONTAP 9 is always enabled and cannot be disabled. It is important that the cluster have the correct date/time set at all times, because job schedules, CIFS authentication, logging, and system processes rely on it.
::> ntp config modify -enabled false
Error: command failed: NTP cannot be turned off. NTP is required for time to be synchronized across nodes in the cluster.
If you do not configure an NTP server, each node will use another node as an NTP server to sync time.
New to NetApp?
Scan to view the article on your device
