How to check cluster interface connectivity in ONTAP 9.9.1 and newer
Applies to
ONTAP 9.9.1+
In previous ONTAP releases the only manual check of cluster interface connectivity was the cluster ping-cluster command. This command is useful; however, it did not provide history of ping tests and is time consuming to run. ONTAP 9.9.1 introduced the network interface check cluster-connectivity commands to provide a better alternative.
