Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
How to capture packet traces (tcpdump) on ONTAP 9.2+ systems
54,590
Visibility:
Votes:
30
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
ONTAP 9.2 to 9.9
Procedure to capture packet traces (tcpdump) on ONTAP 9.2 till 9.9 systems.
Procedure
  • Always filter packet traces on a single client IP whenever possible
  • If multiple clients are affected, select 1 to focus on for troubleshooting
  • Use the -buffer flag on systems with a minimum value of 4096 to ensure the trace doesn't filter packets
  • simple trace:
::> network tcpdump start -node <node> -port <port-or-ifgrp> -address <ip-to-filter-on> -buffer-size 2097151
Note:  ip-to-filter-on may be a client address or a lif on the selected port
  • This will start a packet trace on the specified port on the specified node (wildcards cannot be used for the node or port for this command, and file size of 1 GB).
  • To stop a packet trace:  ::> tcpdump stop -node <node> -port [*|<port>]
  • A simple command to stop all traces is ::> tcpdump stop *
  • To show packet trace files:
::> network tcpdump trace show
  • Packet traces are stored in the following path:
/mroot/etc/log/packet_traces
  • Deleting an old packet trace
::> network tcpdump trace delete ?
   [-node] <nodename>         Node Name
   [-trace-file] <text>       Trace File
Mandatory fields
  • -node
  • -port must be a single physical (example e0g) or virtual port (example a0a-16)
    • NOTE: choosing -port a0a will only capture traffic which is not vlan tagged
    • If a lif is on a vlan, capture traffic on the vlan hosting the lif by specifying the vlan tag number (example -port a0a-16)
Options
::> network tcpdump start -node <node> -port <port> ?
   [[-address] <IP Address>]      IP Address
   [ -protocol-port {1..65535} ]  Protocol Port Number
   [ -file-size {1..65536} ]      Trace File Size in MB
   [ -rolling-traces {1..64} ]    Number of Rolling Trace Files
  • The -port field is mandatory
  • The -address option can specify only one IP address to filter the trace.
  • The -protocol-port option allows for the trace to be filtered by one port for both TCP and UDP traffic.
  • The -file-size option allows for modification of the trace file size from its default (1024 MB).
  • The -rolling-traces option specifies the number of traces files to save if using rolling packet traces.
    • Note: If -rolling-traces is not used, a rolling trace with 2 files will be used.
  • Ensure that node's root volume has enough space if you need to collect large trace files, you can use the 'df -h' command to check it
    • More than twice the total trace size (file size times number of traces) should be available before starting packet traces.
  • Be aware that, by default, the trace files will be added to snapshot copies and that vol0 (root volume) may fill up very quickly causing an outage
  • To avoid consuming root volume space with trace files captured in snapshots, use one of these two options
    • Disable automatic Snapshots on the node root volume from nodeshell of the node where the trace is being collected
      • ::> run -node <node> -command "vol options vol0 nosnap on"
        • Automatic Snapshot copies is disabled. You may consider to delete old snapshots for vol0 based on your space requirements.
    • Delete Snapshots created during a trace
  • After packet-trace collection is finished, re-enable root volume Snapshots if they were originally enabled
    • From nodeshell of the node where Snapshots were disabled
      • ::> run -node <node> -command "vol options vol0 nosnap off"
Rolling trace example
::> network tcpdump start -node <node> -port <port-or-ifgrp> -file-size 512 -rolling-traces 4 -address 10.1.1.2 -protocol-port 445
  • This trace rolls up to 4 trace files of size 512 MB each (oldest file removed first).
  • It traces on the selected port, filtering for IP address 10.1.1.2 and TCP/UDP port 445.]
Retrieving packet traces
  • The packet traces can be downloaded from the following location using a web browser of your choice:
http(s)://<CLUSTER_MGMT_IP>/spi/<NODE_NAME>/etc/log/packet_traces/
Cluster credentials are needed to access the SPI
New to NetApp?
Scan to view the article on your device
