NetApp Knowledge Base
How to apply NTFS permissions on a directory where inherited and non-inherited permissions differ for the same user or group
215
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
cifs
Last Updated:
Applies to
ONTAP 9
  • This process is not the recommended method for NTFS ACL management.
    • It is recommended to use the Windows 'Security' tab whenever possible.
  • NTFS ACLs permissions can be applied to these objects:
    • Current Folder
    • Subfolders
    • Files
You can apply NTFS ACLs to all three, however it is not possible to apply different sets of permissions for the same user.
For example:
vserver security file-directory ntfs dacl add -ntfs-sd <SD-Name> -vserver <vServer-Name> -access-type allow -account "Domain\User_or_Group" -rights modify -apply-to sub-folders,files
The first command was successful
vserver security file-directory ntfs dacl add -ntfs-sd <SD-Name> -vserver <vServer-Name> -access-type allow -account "Domain\User_or_Group" -rights read -apply-tothis-folder
  • The Second command failed with the following error string: error: command failed: duplicate entry
    • The reason for the error is that you cannot add 2 different set of permissions in 1 Security Descriptor (SD) to the same object (user\group).
This ability exists from the Windows side in case of a need: Security Tab > Advanced
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
