Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
How to Disable TLS 1.0 and TLS 1.1 in ONTAP 9.8 and earlier
12,304
Visibility:
Votes:
9
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.8 and earlier
  • ONTAP System Manager
  • I need to disable TLS 1.0 and TLS 1.1 in ONTAP.
  • The security config modify command modifies the existing cluster-wide security configuration.
    • If you enable the FIPS-compliant mode, the cluster automatically selects only TLS protocols.
    • Use the -supported-protocols parameter to include or exclude TLS protocols independently from FIPS mode.
    • By default, FIPS mode is disabled, and ONTAP supports the TLSv1.2, TLSv1.1, and TLSv1 protocols.
    • Reboot is required
New to NetApp?
Scan to view the article on your device
