NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How to Convert a Flexvol with more than 255 snapshots to FlexGroup
450
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FlexGroup
  • ONTAP 9.7 allows converting a FlexVol to FlexGroup
  • However, in ONTAP 9.7
    • FlexGroup can only support less than 255 snapshots
    • FlexVols can support up to 1023 snapshots.
Following errors will be thrown when converting a FlexVol with more than 255 snapshots is all releases of ONTAP 9.7:
cluster01::> version
NetApp Release 9.7P1: Thu Feb 27 01:25:24 UTC 2020
cluster01::>
cluster01::*> volume conversion start -volume myvol -foreground true -check-only true
Error: command failed: Cannot convert volume "myvol" in Vserver "svm1" to a
       FlexGroup. Correct the following issues and retry the command:
       * The volume has more than 254 snapshot copies.  Use the "volume
       snapshot show -vserver svm1 -volume myvol" command to list the Snapshot
       copies present on the volume and remove one or more of them with the
       "snapshot delete -vserver svm1 -volume myvol" command.
       * The volume has Snapshot copies with IDs greater than 255.  Use the
       (privilege: advanced) "volume snapshot show -vserver svm1 -volume myvol
       -logical-snap-id >255 -fields logical-snap-id" command to list the
       Snapshot copies with IDs greater than 255 then delete them using the
New to NetApp?
Scan to view the article on your device
