How do I unencrypt an NAE volume?
Applies to
- ONTAP 9
- NetApp Volume Encryption (NVE)
- NetApp Aggregate Encryption (NAE)
Answer
Perform one of the following steps:
- Use another aggregate:
- Move the volumes to another non-NAE aggregate and convert them to plain text volumes. To do this, you would use the
volume move
commands with the parameter-encrypt-destination false -encrypt-with-aggr-key false.
- Use the same aggregate:
- Assuming you have space in the existing NAE aggregate, move the volumes to convert them from NAE to NVE (which NAE aggregates do allow) in the same aggregate. To do this, use the
volume move
command with the parameter-encrypt-with-aggr-key false.
- After all the volumes are all NVE and no NAE encrypted volumes exist, run the command to disable NAE on the aggregate
aggregate modify -aggregate aggregate_name -node node_name -encrypt-with-aggr-key false
. Make sure that no aggregate Snapshot copies exist, or it will fail. - Move the NVE volumes to unencrypt them and convert from NVE to plain text with
-encrypt-destination false.
Additional Information
