Flexgroup constituents are unbalanced after conversion from Flexvolume
Applies to
- ONTAP 9.7
- Flexgroup
Issue
- A Flexgroup constituent is low on space after conversion
- A Flexgroup volume has unbalanced constituents after it was converted from a Flexvolume and then expanded with the result of having an additional constituent of different size of the first one.
Example:
ontapselect::*> vol show -vserver SVM001 -volume vol_TSP* -fields used,percent-used,size,files,files-used -sort-by used vserver volume size used percent-used files files-used ---------- -------------------- ------- ------- ------------ -------- ---------- SVM001 vol_TSP__0002 642.4GB 50.94GB 7% 21251126 465284 SVM001 vol_TSP__0001 996.0GB 988.9GB 99% 21251126 7458787 SVM001 vol_TSP 1.60TB 1.01TB 63% 42502252 7923823
