NetApp Knowledge Base
FlexVol conversion to FlexGroup reports 'success', but FlexVol is not converted
378
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
FlexGroup Conversion
Issue
Conversion of a FlexVol  to FlexGroup via CLI reports success, however the FlexVol was not actually converted.
Example:
FlexVol conversion is started and reports success:
cluster01::> set -privilege advanced
cluster::*> vol conversion start -volume test -vserver test
Warning: After the volume is converted to a FlexGroup, it will not be possible to change it back to a flexible volume.
Do you want to continue? {y|n}: y
[Job 7891] Job succeeded: success
Job history confirms the FlexVol conversion was successful:
cluster01::*> job history show -id 7891
Time Node Owning Vserver Name Event Job ID
Date Time node vserver
Volume Convert Succeeded 7891
Description: Converting flexible volume to FlexGroup
Completion: success
Volume show still identifies the volume as being a FlexVol (not a FlexGroup):
cluster::*> volume show -vserver test -volume-style-extended flexgroup
There are no entries matching your query.
New to NetApp?
Scan to view the article on your device
