FlexGroup volume create fail
Applies to
- ONTAP 9
- FlexGroup
Issue
- Error with creating FlexGroup volume
::> vol create -volume vol1 -aggr-list aggr01,aggr02,aggr03-aggr-list-multiplier 4 -state online -size 114tb
Notice: The FlexGroup volume "vol1" will be created with thefollowing number of constituents of size 9.50TB: 12.
Do you want to continue? {y|n}: y
Warning: You are attempting to create a FlexGroup volume in Vserver"svm01", which currently uses 32-bit NFSv3
FSIDs and file IDs. Thiscould result in collisions between different file IDs on the FlexGroup volume.
Modify the Vserver to use64-bit NFSv3 identifiers before using the FlexGroup volume with the commands
"set advanced;vserver nfs modify -vserver svm01 -v3-64bit-identifiers enabled".
Error: command failed: Request to provision FlexGroup volume"vol1" failed because the requested size of 114TB
(125344325566464B) is greater than themaximum size. The maximum possible size is 77.09TB (84764508672000B).
- Run the
df -A
command to check the AGGR usage
Aggregate kbytes used avail capacity
aggr01 49129710336 676 49129709660 0%
aggr02 49129710336 1060036 49128650300 0%
aggr03 27603099648 388 27603099260 0%
