Flash cache card missing after ONTAP upgrade, reboot, or firmware update
Applies to
- X3310A/X3311A Flash cache device
- ONTAP 9
Issue
- Adapter Card missing after ONTAP update
Before Upgrade/reboot/firmware update:
Cluster1::> system node run -node <node> -command sysconfig -ac
sysconfig: slot 1 OK: X2071A: 4x12Gb miniSAS HD HBA
sysconfig: slot 3 OK: X3311A: M.2 1TB NVMe Drive
sysconfig: No shelf configuration errors detected.
sysconfig: There are no configuration errors.
Post ONTAP Upgrade/reboot/firmware update:
- Flash Cache Card reseat does not fix the issue
