Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Downgrade BES-53248 firmware from 3.4.4.4 is failing
402
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • BES-53248
  • Firmware Downgrade
  • Firmware Version 3.4.4.4
Issue
Downgrade BES-53248 firmware from 3.4.4.4 is failing with an error:
bes-switch) #copy <file_path_url> active
Mode........................................... HTTP
Set Server IP.................................. <server_ip>
Path........................................... ./
Filename....................................... EFOS-<destination_version>.stk
Data Type...................................... Code
Destination Filename........................... active
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
File transfer in progress. Management access will be blocked for the duration of the transfer. Please wait...
HTTP Code transfer starting...
File transfer operation failed.
New to NetApp?
Scan to view the article on your device
