NetApp Knowledge Base
Does enabling Quotas increase CPU Utilization?
61
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
perf
Last Updated:
Applies to
Data ONTAP 7 and earlier
Answer
CPU utilization is higher from sysstat output when quotas are enabled after upgrading to ONTAP release 7.x or later. User data access may or may not be affected.
Note:
This solution assumes that the /etc/quotas file is properly formatted.
View BUG 179982
Additional Information
Add your text here.
