NetApp Knowledge Base
Do both UDP and TCP connections count towards the 100,000 connection limit per node?
1,247
Visibility:
Votes:
3
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • TCP/UDP
Answer
  • Yes, both UDP and TCP traffic contributes to the 100,000 connection limit per node.
    • Connection ID (CID) limit is 100K
    • UDP is considered stateless, but ONTAP holds an internal "connection-id" open for 2 minutes in case another call comes in on the same ip/port combination
    • UDP CIDs have a lifecycle of at least 4 seconds, but no more than 60 seconds, if idle
    • When 95% of 100K connection limit is breached, ONTAP begins deleting the Least Recently Used (LRU) UDP CID
    • If new connections outpace the deletion rate, new UDP and TCP connections may see intermittent un-responsiveness
Additional Information
additionalInformation_text
