NetApp Knowledge Base
Cluster syslog forwarding: what does each facility represent?
2,313
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Answer
  • The description of each facility is found in the Standard Track document under RFC 5424
  • The default syslogs are tagged kernel and user.
  • Note: ONTAP syslog forwarding uses RFC 3164 compliant timestamps so is not fully compliant to RFC 5424. See Event log server doesn't take ONTAP format for more information.
Additional Information
    [-syslog-facility <Syslog Facility>] - Syslog Facility
This parameter optionally specifies a syslog facility with which the syslog is sent. Possible values for this parameter are default, local0, local1, local2, local3, local4, local5, local6, and local7. If you specify the default syslog facility, syslogs are tagged LOG_KERN or LOG_USER.
