NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Cluster Switch health monitor is reporting 'Invalid SNMP Setting' in 9.8 and later
311
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
network
Last Updated:
Applies to
  • Cluster Network Switch
  • ONTAP 9.8
Issue
  • In ONTAP 9.8 and later, an attempt to create a cluster switch entry using the commands 'system cluster-switch create' or 'system switch ethernet create' fails with the following error message:
cluster1::> set advanced
cluster1::*> system switch ethernet create -device switch1 -address 10.10.10.1 -model OTHER -type cluster-network -is-monitoring-enabled-admin true
Error: SNMP validation request timed out. Verify that the "-community-or-username" value is valid.
  • The 'Reason' field of the 'system cluster-switch show' command output has the value 'Invalid SNMP Settings'
cluster1::> system cluster-switch show -type cluster-network
Switch Type Address Model
switch1 cluster-network 10.10.10.1 N9K-C9336C-FX2
Serial Number: XXXXXXXX
Is Monitored: false
Reason: Invalid SNMP Settings
Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
9.3(8)
Version Source: CDP/ISDP
  • There are no network connectivity issues between ONTAP and the switch
  • A '/usr/bin/bsnmpwalk' to the switch is successful
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
