Cluster LIF not found in Database after MB replacement
Applies to
- ONTAP 9
- FAS2520
Issue
- After replacing motherboard on node, the cluster network is down.
- Attempt to revert cluster LIF after motherboard replacment fails with an error similar to the following:
::> net int revert -vserver * -lif *
(network interface revert)
Error: command failed on vserver "Cluster" lif "ClusterLif_1": LIF
"Cluster;ClusterLif_1" could not be found in database (RPC:
Couldn't make connection [from mgwd on node "Node1" (VSID: -1)
to vifmgr at xxx.xxx.xxx.XXX]). Contact technical support for
assistance.
- After replacing motherboard, ports are missing from the Cluster IPspace
Example:
::> net port show (network port show) Node: CLUS-02 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0M Default - up 1500 1000/1000 - e0a Default - up 1500 1000/1000 - e0b Default - up 1500 1000/1000 - e0c Default - up 9000 10000/10000 - e0d Default - up 9000 10000/10000 - e0e Default - up 9000 10000/10000 - e0f Default - up 1500 1000/1000 -
