Cannot create aggregate using partitions in a mixed cluster of FAS and AFF systems
Applies to
- ONTAP 9.7P1 and later
- ONTAP 9.6P6 and later
- ONTAP 9.5P11 and later
- Mixed Cluster of AFF and FAS systems
- Four or more nodes in a cluster
- Advanced Disk Partitioning (ADP)
Issue
Aggregate creation in a cluster with mixed partitioning methods fails:
Cluster01::> storage aggregate create -aggregate aggr3 -simulate true -disklist 5.0.1,5.0.3,5.0.5,5.0.7,5.0.9,5.50.1,5.50.3,5.50.5,5.50.7,5.50.9,5.50.11,5.51.1,5.51.3,5.51.5,5.51.7,5.51.9,5.51.11 -node cluster01-03
Error: command failed: Disk "5.0.1" is partitioned with the "root-data" method, which is not supported on this system since this system is initialized with "root-data1-data2". Contact technical support for assistance
Note: the issue can also occur in the reverse. For example:
Error: command failed: Disk "5.0.1" is partitioned with the "root-data1-data2" method, which is not supported on this system since this system is initialized with "root-data". Contact technical support for assistance
