NetApp Knowledge Base
CSHM: ClusterSwitchConfig_Alert: System health degraded due to wrong Cluster Switch cabling
3,459
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Cluster Switch Health Monitor (CSHM) AutoSupport message
Issue
  1. System health is degraded
cluster::>system health status show
Status
degraded
  1. Switch-Health subsystem is degraded
cluster::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     degraded
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
13 entries were displayed.
  1. The following health alerts are logged
cluster::> system health alert show
Node: node01
Resource: node01
Severity: Major
Indication Time: Mon Oct 07 13:19:08 2019
Suppress: false
Acknowledge: false
Probable Cause: One or more nodes are not connected to both cluster switches.
Possible Effect: If one cluster switch fails, "node01" might lose access to the cluster.
Corrective Actions: Ensure the switch "switch02" is connected to the node "node01".
Node: node01
Resource: node02
Severity: Major
Suppress: false
Acknowledge: false
Possible Effect: If one cluster switch fails, "node02" might lose access to the cluster.
Corrective Actions: Ensure the switch "switch01" is connected to the node "node02".
2 entries were displayed.
4. You could also see the following heath alerts
               Node: cluster-01
           Resource: Ethernet1/1
          Severity: Minor
    Indication Time: Wed Aug 25 05:23:27 2021
           Suppress: false
        Acknowledge: false
     Probable Cause: MTU value "1500" on port "e0e" of node
                     "cluster-01" is improperly set. It
                     should be 9000.
    Possible Effect: Received Ethernet packets that are larger than the
                     configured MTU are dropped, causing data transfer
                     issues.
Corrective Actions: modify the MTU using the command "network port
                     broadcast-domain modify -ipspace Cluster
                     -broadcast-domain Cluster -mtu <MTU>". To find out the
                     broadcast domain name of the port, execute the command
                     "network port broadcast-domain show".
5. AutoSupport reports:
HMSCSA:HA Group Notification from cluster1-03 (Health Monitor process cshm: ClusterSwitchConfig_Alert[cluster1-03]) ERROR
New to NetApp?
