Are Local Users and Groups Supported for CIFS/SMB in ONTAP?
Applies to
- ONTAP 9
- CIFS/SMB
Answer
- Local users and groups (LUG) is the ability to create user accounts that are local to a Vserver.
- Authentication and Authorization can be done by using the local users and groups, usually in extreme situations.
- LUG has been supported since Data ONTAP 8.2 and later.
- How to enable LUG in Data ONTAP 8.2+ and ONTAP 9?
- MAN: cifs users-and-groups
- Enabling or disabling local users and groups:
Cluster::>set advanced
Cluster::*>vserver cifs options modify -vserver vserver_name -is-local-users-and-groups-enabled true/false - Enabling or disabling local user authentication:
Cluster::*>vserver cifs options modify -vserver vserver_name -is-local-auth-enabled true/false
Additional Information
How to create a local user to access a CIFS share? - NetApp Knowledge Base
