NetApp Knowledge Base
Are Hybrid Aggregates supported for FabricPool
246
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Hybrid Aggregate
  • FlashPool
  • FabricPool
Answer
No, Hybrid ( FlashPool ) aggregates are not supported for FabricPool.
  • FabricPool is only supported on all SSD or all HDD aggregates.
Following error message will be reported when attempting to convert a Hybrid aggregate to FabricPool:
cluster01::*> storage aggregate object-store attach -aggregate hya_aggr -object-store-name my-store-1
Warning: Once an aggregate becomes a FabricPool, there is no way to reverse the
process and make it a non-FabricPool. Do you want to continue?
{y|n}: y
Error: command failed: Cannot attach object store to hybrid-enabled aggregates.
Additional Information
