NetApp Knowledge Base
ASUPs fail when using two cluster or node management LIFs on the same node
172
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport
Issue
  • Two cluster or node management LIFs are configured on one node, and when both are enabled, ASUPs fail to send from the node hosting the two LIFs.
  • In multi-node clusters, the issue may look as if ASUPs are being sent from all nodes except one
  • ASUPs tend to fail for whichever node is the home node of the two mgmt LIFs.
  • This sometimes occurs because the node attempts to send ASUPs using the secondary mgmt LIFs route instead of the nodes primary mgmt LIF route.
New to NetApp?
  • Was this article helpful?
