NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
NetApp Knowledge Base
ASUP transmission failed when sent from Cluster management IP
718
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport (ASUP)
  • HTTP/HTTPS
Issue
  • Node hosting the cluster management LIF is not sending ASUP
  • When cluster management LIF is moved to another node, the issue migrates with it
  • Command autosupport check show-details points to an issue with the Proxy :
Component: http-post-destination
Status: failed
Detail: HTTP/S POST connectivity check failed for destination:
https://support.netapp.com/asupprod/post/1.0/postAsup
via proxy - proxy.domain.com:8080. Error: Possible ProxyAuthentication issue.
Corrective Action: Ensure the user-id and password are set correctly forthe proxy URL.
  • Command autosupport history show
Status: transmission-failed
Error: Received HTTP code 404 from proxy after CONNECT
New to NetApp?
Scan to view the article on your device
