ANDU paused due to connectivity with Fabric Pool
Applies to
- ONTAP 9
- Fabric Pool
Issue
During the update from 9.9.1x to higher version, giveback canceled with errors:
- From the node who s giving back the aggregate we see :
[cf_giveback: sfo.sendhome.subsystemAbort:alert]: The giveback operation of 'aggr_data' was aborted by 'fabric pools'.
- The node who should take the aggregate back shows following:
[object.store.unavailable:EMERGENCY]: Unable to connect to the object store "s3" from node 21d07150-ac6c-11ec-8fea-d039ea4d986c. Reason: Connection unavailable.
[ktlsd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '10.x.x.x' in IPspace '4294967295', for which the latest reason given is: OpenSSL: error:0A000086:SSL routines::certificate verify failed."
