NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
7MTT to clustered Data ONTAP migration fails with "Reason: A technical error has occurred"
256
Visibility:
Votes:
0
Category:
clustered-data-ontap-8
Specialty:
core
Last Updated:
Applies to
7-Mode Transition Tool (7MTT)
Issue
The transition job stops during the pre-cutover phase with 'Reason: A technical error has occurred':
"message" : "Reason: A technical error has occurred.",
"type" : "BLOCKING_ERROR",
"unSupportedVersions" : [ ],
"aptSummaryMessage" : null,
"aptDetailMessage" : null,
"aptDetailCorrectiveAction" : null, "aptSummaryCorrectiveAction" : null,
"7ModeAffectedResources" : null,
"code" : "01061",
"correctiveAction" : "Contact technical support.",
The SnapMirror relationships are idle and in the broken-off state.
The transition log reports that the job has crashed:
2014-12-23 12:51:46.455 MEZ [c.n.t.j.TransitionThreadPoolExecutor: ERROR] [job-mngr-1] [operation-name: precutover]: Job crashed.java.util.NoSuchElementException: null
at com.sun.xml.internal.stream.EventFilterSupport.nextEvent(Unknown Source) ~[na:1.7.0_55]
at com.netapp.autozapi.marshal.ApiReader.readPrimitiveObject(ApiReader.java:235) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.marshal.ApiReader.readFields(ApiReader.java:135) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.marshal.ApiReader.readResponse(ApiReader.java:358) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.BeanXmlZapiInvocation.createPassedResponse(BeanXmlZapiInvocation.java:118) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.BeanXmlZapiInvocation.createPassedResponse(BeanXmlZapiInvocation.java:70) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.XmlZapiInvocation.readResponse(XmlZapiInvocation.java:215) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.ZapiInvocation.processResponse(ZapiInvocation.java:249) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.ZapiInvocation.invoke(ZapiInvocation.java:117) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.XmlZapiInvocation.invoke(XmlZapiInvocation.java:40) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.ZapiRunner.run(ZapiRunner.java:155) ~[autozapi-runtime.jar:3.0]
at com.netapp.autozapi.client.ZapiRunner.run(ZapiRunner.java:125) ~[autozapi-runtime.jar:3.0]
at com.netapp.transition.common.zapirunner.ZapiRunnerUtil.executeZapi(ZapiRunnerUtil.java:171) ~[transition-common.jar:2.0]
at com.netapp.transition.common.zapirunner.ZapiRunnerUtil.executeSystemCli(ZapiRunnerUtil.java:129) ~[transition-common.jar:2.0]
at com.netapp.transition.common.zapirunner.ZapiRunnerUtil.executeSystemCli(ZapiRunnerUtil.java:84) ~[transition-common.jar:2.0]
at com.netapp.transition.common.zapirunner.ZapiRunner7Mode.executeVfilerizedSystemCli(ZapiRunner7Mode.java:270) ~[transition-common.jar:2.0]
at com.netapp.transition.common.util.ontap.OnTapCifs7ModeOps.fetchNameForSid(OnTapCifs7ModeOps.java:267) ~[transition-common.jar:2.0]
at com.netapp.transition.operations.configfiles.CifsShareAclsOperations.collectData(CifsShareAclsOperations.java:187) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.collect.CifsCollectHandler.collectCifsAclConfig(CifsCollectHandler.java:336) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.collect.CifsCollectHandler.execute(CifsCollectHandler.java:146) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.TransitionCollectOp.execute(TransitionCollectOp.java:98) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.complete.CTAHelper.collect(CTAHelper.java:62) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.complete.TransitionPrecutoverHandler.doCTA(TransitionPrecutoverHandler.java:289) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.complete.TransitionPrecutoverHandler.execute(TransitionPrecutoverHandler.java:139) ~[transition-operations.jar:2.0]
at com.netapp.transition.operations.TransitionPrecutoverOp.execute(TransitionPrecutoverOp.java:164) ~[transition-operations.jar:2.0]
at com.netapp.transition.jobmanager.PrecutoverJob.execute(PrecutoverJob.java:129) ~[transition-job-manager.jar:2.0]
at com.netapp.transition.jobmanager.AbstractJob.run(AbstractJob.java:183) ~[transition-job-manager.jar:2.0]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_55]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_55]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_55]
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
