NetApp Knowledge Base
"volume efficiency start" command fails with error "Cannot perform efficiency operations on deprioritized volume"
1,558
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Issue
  • When running "volume efficiency start", command fails with the following error.
Example:
Error: command failed: Failed to start efficiency on volume "volume_name" of Vserver "vserver_name": Cannot perform efficiency operations on deprioritized volume.
To be able to perform efficiency operations, run "volume efficiency promote" command first.
  • But when running "volume efficiency promote" command as suggested, it reports the following error.
Example:
Error: "promote" is not a recognized command
New to NetApp?
