"vol move" stuck with "Deduplication operation is not configured" error
Applies to
ONTAP 9
Issue
- When
vol move
is performed, "Deduplication operation is not configured error
" is repeatedly output tomgwd.log
and the process does not proceed.
Example:
[kern_mgwd:info:2036] 0x81f38d500: 8603ef00000ac52e: WARNING: VOPL::DbladeZapiServerConnection: ksmfDbladeIf::setupMoveSourceForTransfer 833 failed operation forVolume Id: XXXX error-no : 1259827 error-string : Deduplication operation is not configured detailed error: move_agent.cc:452: Error:14643, CR_Error:CR_NO_ERROR(0), WAFL_Error:0
[kern_mgwd:info:2036] 0x81f38d500: 8603ef00000ac52e: ERR: VOPL::VolumeObject: FlexVolume::setupMoveSourceForTransfer: failed to prepare for jobId(XXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXX), vserverId(0x0000000X), clusterId(XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX), aggrId(XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX), volName(XXXXXXX), msid(0x0x000000008000XXXX), dsid(0x0x000000000000XXXX), err(code=14643,module=19,msg=Deduplication operation is not configured), reason(Deduplication operation is not configured).
[kern_mgwd:info:2036] 0x81f38f300: 8603ef00000ac52e: WARNING: VOPL::VolMove: 125964 refreshTransferEngineInterfaces 12424 VolMoveJob::refreshing transfer engine interfaces, due to last error code = 14643. Preparing the source of the volume move for transfer: Deduplication operation is not configured
" would be observed from output of"volume move show -instance"
as well.
Example:
Cluster::> volume move show -instance
Vserver Name: SVM1
Volume Name: vol_test
Actual Completion Time: -
Bytes Remaining: 573.3GB
Destination Aggregate: aggr2
Detailed Status: Volume move job at decision point
Error: Preparing the source of the volume move for transfer: Deduplication operation is not configured
Estimated Time of Completion: Tue Dec 21 11:09:03 2021
Managing Node: node2
Percentage Complete: 98%
Move Phase: replicating
Estimated Remaining Duration: 00:00:30
Replication Throughput: 464.2MB/s
Duration of Move: 5 days 03:04
Source Aggregate: aggr_src2
Start Time of Move: Thu Dec 16 08:04:24 2021
Move State: warning
Is Source Volume Encrypted: false
Encryption Key ID of Source Volume:
Is Destination Volume Encrypted: false
Encryption Key ID of Destination Volume:
