"Takeover is not possible: Local node missing partner disks" due to disk in testing
Applies to
ONTAP 9
Issue
- One disk in testing
Maintenance disks
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
testing 0a.10.3 0a 10 3 SA:B 0 SAS 10000 1713523/3509295616 1716957/3516328368 (fast zeroed)
- Partner node shows
::>Storage failover show
Takeover
Node Partner Possible State Description
Node B Node A true Connected to Node A
Node A Node B false Connected to Node B, Takeover is not possible: Local node missing partner disks
- If the testing disk is running and "Reason Takeover not Possible Local node missing partner disks" is output, the HA function will not work properly.
- Please implement the steps in the Solution as soon as possible.
