MAX Data service fails to start after installation
Applies to
MAX Data Installation
Red Hat Enterprise Linux (RHEL)
Community Enterprise Operating System (CentOS)
Issue
- After installing and configuring MAX Data, max_setup will not start following a reboot.
[root@wrx-madmax-2 ~]# systemctl status max_setup -l
max_setup.service - SDM automated setup service
Loaded: loaded (/usr/lib/systemd/system/max_setup.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2018-09-13 16:06:22 PDT; 5s ago
Process: 14668 ExecStart=/usr/bin/max_configurator.py setup --up --log_to_console (code=exited, status=1/FAILURE)
Main PID: 14668 (code=exited, status=1/FAILURE)
- Attempting to start
max_setup
may lead to the following:
[root@wrx-madmax-2 ~]# systemctl start max_setup
Job for max_setup.service failed because the control process exited with error code. See "systemctl status max_setup.service" and "journalctl -xe" for details.
- Running
journalctl -xe
shows:
11/21/2019 15:32:49 INFO Building all applications file system
11/21/2019 15:32:49 INFO Building file systems for application: 'oracle'
11/21/2019 15:32:49 INFO Building file system for m1fs: 'oracle'
11/21/2019 15:32:49 INFO Creating new file system (provision flow) for m1fs: 'oracle'
11/21/2019 15:32:49 INFO Executing mkfs (options: --force --acl --nodiscard --UUID=ca074564-3c85-4512-8e8b-32061af45166, T1 devices: /dev/pmem0p1, T2 devices: /dev/disk/by-path/fc---lun-0 /dev/disk/by-path/fc---lun-0 /dev/disk/by-path/fc---lun-0 /dev/disk/by-path/fc---lun-0)
11/21/2019 15:32:49 ERROR MKFS failed, command output: mkfs.m1fs version 18.1
Open error for '/dev/disk/by-path/fc---lun-0' - Device or resource busy
11/21/2019 15:32:49 INFO Rolling back all applications
