NetApp Knowledgebase
How to configure WinZip to properly extract .tar/.tgz files
78
Visibility:
Votes:
1
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • WinZip
  • tar files (typically .tar and .tgz)
A configuration setting in WinZip - the 'TAR file smart CR/LF conversion' option - is enabled by default and will cause tar files to be altered/corrupted during extraction. This default behaviour often leads to the misconception that WinZip "does not work".
The 'TAR file smart CR/LF conversion' option is not suitable for binary files (i.e., image.tgz) and must be disabled. The Procedure below describes how to disable that option so that WinZip can be used successfully with ONTAP software images and other binary tar/tgz archives.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
