upgrade-mnode script on mNode failing with error: Failed to establish a new connection: Errno 111 Connection refused
Applies to
- mNode 11.1
- mNode 11.0
- mNode 11.8
Issue
After successful upgrade of the mNode to 11.8, the mnode-upgrade script to configure the mNode fails
mNodeCLI # /sf/packages/mnode/upgrade-mnode -mu <mnode user>
- Traceback (most recent call last):
File "setup_scripts/config_util.py", line 102, in retry_operation
File "setup_scripts/mnode_api_client.py", line 31, in get_root_assets
File "setup_scripts/mnode_api_client.py", line 339, in retry_on_401
File "requests/sessions.py", line 521, in get
File "requests_oauthlib/oauth2_session.py", line 425, in request
File "requests/sessions.py", line 508, in request
File "requests/sessions.py", line 618, in send
File "requests/adapters.py", line 508, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='localhost', port=443): Max retries exceeded with url: /mnode/1/assets (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fcb42076550>: Failed to establish a new connection: [Errno 111] Connection refused',))
[2020-04-29T12:06:49.864850Z]:[mnodecfg:69] ERROR:HTTPSConnectionPool(host='localhost', port=443): Max retries exceeded with url: /mnode/1/assets (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fcb42076550>: Failed to establish a new connection: [Errno 111] Connection refused',))
- The script will perform automatic clean up, so after a failure there will be no running containers.
mNodeCLI $ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
