NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
setup-mnode script or Management Services update fails on Element mNode 12.2+ with configure_element_auth error
1,155
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • Element management node (mNode) version 12.2 and above
  • NetApp Element storage clusters running on one of the following Element versions:
    • 11.3
    • 11.5
    • 11.7
    • 12.0
    • 12.2
    • 12.3
Issue
  • While either attempting to set up the mNode using the /sf/packages/mnode/setup-mnode script or when updating Management Services on the mNode, the process fails with an accompanying auth error (in /var/log/sf-nde.info):
ERROR    [auth_utilities.py:112] 400 Client Error: Bad Request for url: https://x.x.x.x/auth/api/1/configuration
ERROR:Uncaught Exception:
Traceback (most recent call last):
  File "setup_scripts/config_util.py", line 1549, in configure_element_auth
  File "docker/models/containers.py", line 814, in run
docker.errors.ContainerError: Command 'None' in image 'reconfigure-auth-sidecar:1.0.4' returned non-zero exit status 1: b'2021-01-22 21:37:04.105 INFO     [logger.py:153] Log level for reconfigure-auth-sidecar has been set to INFO\n2021-01-22 21:37:04.107 INFO
  • You may also see this error while setting up the mNode:
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 943, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 503 Server Error: Service Unavailable for url: https://<MVIP>/auth/api/2/configuration
2021-05-24 23:27:36.873 DEBUG [auth_utilities.py:207] Response: Reconfiguration failed with HTTP error: "503 Server Error: Service Unavailable for url: https://<MVIP>/auth/api/2/configuration". See log for traceback., RC: 503
2021-05-24 23:27:36.873 ERROR [auth_utilities.py:209] Reconfiguring auth failed. Aborting deployment. Got error: "Reconfiguration failed with HTTP error: "503 Server Error: Service Unavailable for url: https://<MVIP>/auth/api/2/configuration". See log for traceback."
  • This error may also be present
    • Failed to update element-auth configuration
  • The setup-mnode script is failed with the same error as above when the cluster is still in upgrade mode (eg,11.5->12.3).
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
