NetApp Knowledge Base
Which API calls will not work during an Element software upgrade?
801
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp Element software
Answer
This list contains all API calls you cannot make during an Element software upgrade.
Note that the API's below with the * are APIs that allow the forceDuringUpgrade override by NetApp Support. All others are disabled while the upgrade is in progress.
Warning: Caution should be taken when running APIs while a cluster is in 'Upgrade Mode'. If any of these APIs should be run while upgrading, please contact NetApp Technical Support and reference this article for further assistance.
  • AddNodes*
  • RemoveNodes*
  • AddDrives*
  • RemoveDrives*
  • CreateInitiators*
  • DeleteInitiators*
  • ModifyInitiators*
  • CreateVolumeAccessGroup*
  • ModifyVolumeAccessGroup*
  • ModifyVolumeAccessGroupLunAssignments*
  • AddInitiatorsToVolumeAccessGroup*
  • RemoveInitiatorsFromVolumeAccessGroup*
  • AddVolumesToVolumeAccessGroup*
  • RemoveVolumesFromVolumeAccessGroup*
  • DeleteVolumeAccessGroup*
  • SecureEraseDrives
  • EnableEncryptionAtRest
  • DisableEncryptionAtRest
  • AddVirtualNetwork
  • RemoveVirtualNetwork
  • ModifyVirtualNetwork
  • EnableFeature
  • SetSSLCertificate
  • RemoveSSLCertificate
  • SetClusterStructure
  • CheckProposedNodeAdditions
  • SetSupplementalTlsCiphers
  • ResetSupplementalTlsCiphers
*APIs that can be performed with forceDuringUpgrade option.
Notes:
  • Beginning with Element software 11.7 and later, API restrictions will be lifted for iSCSI-only clusters during upgrades
  • API restrictions will continue to apply to any cluster containing Fibre Channel (FC) nodes, regardless of the Element software version
Additional Information
additionalInformation_text
