NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Unable to extend datastores using Solidfire vCenter plugin
18
Visibility:
Votes:
0
Category:
sf-series
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp vCenter plugin for Solidfire (VCP) 4.6
  • NetApp Element OS 12.3
Issue
  • NetApp vCenter plugin for Solidfire fails to extend or create new datastore. It can create new volumes OK.
  • The VCP log ( var/log/vmware/vsphere-ui/logs/solidfire.log) show error as follows -
2021-10-25 20:54:50 DEBUG VsphereTaskServiceImpl:78[pool-6-thread-1] - Create task type=CREATE_DATASTORE, initiator=xxx\xxx, cancelable=false
2021-10-25 20:54:50 ERROR WSClient:99[pool-6-thread-1] - Exception caught while invoking method: UpdateExtension
com.vmware.vim25.SystemError: lookup.fault.EntryNotFoundFault
  • The vCenter VPXD log shows that it is not finding the plugin even though its registered
2021-10-25T20:54:50.044Z info vpxd[05555] [Originator@6876 sub=vpxLro opID=183b442] [VpxLRO] -- BEGIN lro-47482646 -- ExtensionManager -- vim.ExtensionManager.updateExtension -- 521ea7f5-b565-6a21-5e37-3494fd82f05d(521dec40-b6fb-0aee-3c00-a3a42b63312a)
2021-10-25T20:54:50.156Z error vpxd[05555] [Originator@6876 sub=SoapAdapter opID=183b442] Method vim.ExtensionManager.updateExtension threw undeclared fault of type vmodl.MethodFault
2021-10-25T20:54:50.156Z info vpxd[05555] [Originator@6876 sub=vpxLro opID=183b442] [VpxLRO] -- FINISH lro-47482646
2021-10-25T20:54:50.156Z info vpxd[05555] [Originator@6876 sub=Default opID=183b442] [VpxLRO] -- ERROR lro-47482646 -- ExtensionManager -- vim.ExtensionManager.updateExtension: lookup.fault.EntryNotFoundFault
--> Result:
--> (lookup.fault.EntryNotFoundFault) {
--> faultCause = (vmodl.MethodFault) null,
--> faultMessage = <unset>,
--> errorMessage = "Entry with name serviceId: 0b58fbee-cf74-4399-ba63-dfbc0fb227c3_com.solidfire not found.",
--> name = "serviceId: 0b58fbee-cf74-4399-ba63-dfbc0fb227c3_com.solidfire"
--> msg = "Received SOAP response fault from [<cs p:00007f1f800399d0, TCP:abcd.com:443>]: set
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
