NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
NetApp Knowledge Base
Sfinstall upgrade process exits due to xVolumeIDDoesNotExist error
65
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp Element Software
Issue
  • The upgrade process exits with the below error (sfinstall command output)
2022-01-18 07:19:42: PostInstallKexecLoad 87%:Loading kexec kernel
2022-01-18 07:36:12: FinishSuccess 100%: RTFI PostInstall successful
2022-01-18 07:36:14: cGCSendBloomFiltersInSeparateThreadEnable is not a supported cluster constant.
2022-01-18 07:36:14:Upgrade error: packageName=[./solidfire-rtfi-magnesium-patch3-12.3.0.958.iso] ex=[SolidFireApiError server=[10.xx.xx.xx] method=[ListVolumeStatsByVolume], params=[{}] - error name=[xVolumeIDDoesNotExist], message=[Volume 1422 does not exist.],code=[500], retryable=[False]]
  • From the event log at the above error time,  the volume is deleted and purged.
2022-01-18T07:36:13.159Z apiEvent API Call (PurgeDeletedVolume)  1  { "success": true, "params": { "volumeID": 1422, "requestAPIVersion": "1.0" }, "method": "PurgeDeletedVolume", "context": { "ip": "10.xx.xx.xx", "authMethod": "Cluster", "user": "cinderuser" } }
2022-01-18T07:36:13.090Z apiEvent API Call (DeleteVolume)  1  { "success": true, "params": { "volumeID": 1422, "requestAPIVersion": "1.0" }, "method": "DeleteVolume", "context": { "ip": "10.xx.xx.xx", "authMethod": "Cluster", "user": "cinderuser" } }
New to NetApp?
Scan to view the article on your device
