NetApp Knowledge Base
NVRAM device problems detected, metadata drive will be removed
2,160
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp Element software
  • NetApp SolidFire SF-Series node
  • NetApp H-series
Issue
  • Metadata drive moves to Available state or node rebooted unexpectedly
  • On NetApp SolidFire Active IQ, one or more of the following alerts appear:
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. error={No device found}
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. error={NVRAM device partition doesn't exist}
    • NodeOffline - The SolidFire Application cannot communicate with node ID <#>
    • NVRAM device error={No device found}
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. warning={1 activeFirmwareVersion: incorrect version 0.0} critical={Device: 1 Key: armStatusSaveNArmed}
    • NVRAM device problems detected, metadata drive will be removed. Contact NetApp Support. warning={excessiveCapacitorVoltage (XXXx)} error={derivedCapacitanceOfThePack: X.XXX F, derivedEsrOfCapacitorPack: XX.XXX Ohm}
New to NetApp?
