NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
How to reboot an Element storage node
5,711
Visibility:
Votes:
1
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp Element software
  • NetApp SolidFire
  • NetApp HCI
  • NetApp SolidFire SF-Series node
  • NetApp H-series storage nodes
  • This article outlines the procedure to reboot a storage node that is running Element Software
  • In rare instances, it may be necessary to reboot a storage node that is running Element software. This should be done only when needed and under the direction of NetApp Support
Important:
  • The procedures for rebooting a node that is not in a cluster versus a node that is part of a cluster are different.  Both procedures are covered in this article
  • If a node is being rebooted because it is hung, has a hung process, or is experiencing other issues within Element then an alternative reboot method may be desired so a crash dump will be generated to assist in troubleshooting the cause of the hang
  • NetApp Support will advise on the type of reboot that is required based on the issue at hand
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
