NetApp Knowledge Base
How do Unaligned Writes affect a volume on Element software?
370
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp Element software
Answer
  • Why do we see unaligned writes to volumes without data?
    • These volumes are being written to and are not empty. We can see non-zero blocks and constant 1-2kb/s writes on each volume. Any write can be unaligned so we will see unaligned writes to any volume that has been written to.
  • What causes unaligned writes?
    • The unaligned write counter increments when either a 512-byte read or a write does not end on the 4k block size boundary. False positives can also be logged when blocks smaller than 4k are sent.
    • In the event the volume is showing a small number (typically less than 5% of the block written) of increments, then this is likely due to false positives.
  • What actions need to be taken to stop the unaligned writes?
    • No actions need to be taken to stop the unaligned writes. There will always be unaligned writes when writing to SolidFire. There are 3rd party tools available that will re-align writes but these come with their own risks and are not supported by NetApp.
  • What will be the impact of such unaligned writes?
    • In Element Software 9.3 we significantly improved performance for unaligned writes. Since this release, we have no evidence of noticeable performance issues caused by unaligned writes.
  • Will it cause any performance degradation?
    • Unaligned writes are not as ideal as aligned writes and may require additional I/O but the impact to performance on SolidFire is negligible on Element Software 9.3+. If performance issues are encountered, contact NetApp Support to take a closer look. Most performance issues involve QoS, hardware, network, or host configuration and unaligned writes have not been a common cause for performance escalations.
Additional Information
