NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How are Dedupe Ratios Calculated in Element Software?
101
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
Element Software
Answer
Deduplication (dedupe) refers to the elimination of redundant data by Element Software. This occurs at the individual block level -- if a given block's data is identical to another's, only one block will be retained, and the metadata will point to the existing block rather than to two identical blocks.
The dedupe ratio is the ratio of total data to unique data in a given context (for instance, globally across the cluster or within a given account). This ratio can be a little hard to understand, in that a small change in the ratio corresponds to a larger percentage change in the amount of shared data.
For example, take a cluster with 4 VMs each 20GB in size.
If they share 5GB  of data each (25%) the dedupe ratio would be (80 GB Total / 65 GB Unique) = 1.23x Dedupe
If they share 10GB of data each (50%) the dedupe ratio would be (80 GB Total / 50 GB Unique) =  1.6x Dedupe
If they share 15GB of data each (75%) the dedupe ratio would be (80 GB Total / 35 GB Unique) =  2.3x Dedupe
In the example, the Dedupe ratio between the first two changes by less than four tenths, but the percentage changes from 25% to 50% of shared data.  The ratios change more drastically beyond 50% of shared data.
Additional Information
Sample data based on 1000 volumes and 250TB of used space.
Percent Shared Unique Data Total Data Dedupe Ratio
0% 250000000 250000000 1.00
5% 237512500 250000000 1.05
10% 225025000 250000000 1.11
15% 212537500 250000000 1.18
20% 200050000 250000000 1.25
25% 187562500 250000000 1.33
30% 175075000 250000000 1.43
35% 162587500 250000000 1.54
40% 150100000 250000000 1.67
45% 137612500 250000000 1.82
50% 125125000 250000000 2.00
55% 112637500 250000000 2.22
60% 100150000 250000000 2.50
65% 87662500 250000000 2.85
70% 75175000 250000000 3.33
75% 62687500 250000000 3.99
80% 50200000 250000000 4.98
85% 37712500 250000000 6.63
90% 25225000 250000000 9.91
95% 12737500 250000000 19.63
100% 250000 250000000 1000.00
Scan to view the article on your device
